Clutch will not let go????
90consuela
- Millers Creek, NC
- '76 CJ7 304 w/ 3 Speed (missing most of its body parts) D30 w/ Drums up front and AMC 20 Rear...SOLD!
'94 YJ Stock as hell!
'07 Dodge 2500 Cummins 2 wheel deal
I think all you need to do is drill and tap your jeep bellhousing.
I used to have a '82 CJ7 that I installed a Ford T18 into.
The when I put the transmission up against the bellhousing it obvious how they fit together but I had to drill and tap the bellhousing to bolt them together. It was easy. Now I had a T5 transmission (getting removed) and a '82 258.
As for the clutch I called up the guys at Centerfoce to get what I needed. The Ford tranny had a different diameter input shaft with a different number of splines so I ended up with a friction plate intended for a Ford and a pressure plate intended for a Jeep.
EDIT: I'm confused by your last post. Are we going to a ford or a dodge tranny?
I have a dodge bellhousing mounted to a np435, that's why I was saying that I should get a ford bellhousing. I guess that the best thing to do, though, is to just try to mount it up to the jeep one? And then source the clutch and pressure plate.
OK I understand now...I thought that the transmissions were the same and the bellhousings were different to adapt them to different blocks. I didnt take in to account the input shafts and so-on. I will be giving them both a ring. Thanks buddy
