Contour Dual Fan
Contour Dual Fan
ThisGuyUKnow
Full Time Jeeper
Featured
Harleysville, PA
1986 CJ7 Laredo 4.0,Nv3550,D300 Twin Stick,AMC20 3.31, 31 BFG
Honda vtx1800c
Up Brock thanks. I was already planning to use that autozonE controller in the second contour link. So good stuff. I have been runnin a non adjustable controller on the Taurus fan. I have to say the adjustable is the way to go. The non adjustable kep the AMC 258 i6 / 4.2l on the hot side. Compare itto my waggy which runs the same fan but has the adjustBle contoller and I can keep it just below 200 degs(accordingto my wag's temp gauge)
I guess j should mention tha the waggy has a 360
If you don't mind me asking...what did the contour fan assembly sell for?
This looks like a great mod!!
They vary in price depending on local demand.
I can pick one for about $20 here but back home I'd be lucky to even find one.
My local pull it charges 16 dollars for electric radiator fans plus I you hve a core, which I do, they give you some money back. However; the prick at the counter charged me for 2 fans so it cost me 32.:mad: that pisses me off because it's one damn assembly. But whatever 32 isn't bad I guess
I went back to the U-pullit today for another contour fan to fit into my grand wagoneer. THis will also be replacing a taurus fan that I was running.
The fan I was using in my CJ still had the paint the upullit puts on stuff you get from them to prove that it came from them in the event you try to return it. So I told the guy at the counter that I had bought it yesterday (still had the receipt) but I just wanted to use it as credit toward a dual fan set up. So when I got to the counter after pulling the fan I handed the receipt to the counter guy and he didn't charge me for the extra fan on the assembly.:rolleyes: I didn't bother to correct him that the fan I was exchanging for it was a single fan. So in the end each fan cost me 16 dollars. If you dont count that I paid 16 dollars for my taurus fan back in january.
It is seriously a feat to get these fans out of the contours. It literally took about an hour to get each out without breaking it. The tauri fans just pop out with minimal effort and you just have to reshape the shroud. I basically took a crow bar with me and broke off any piece in my way then I still had to some how get the bolts on the back of the fan to clear a part of the engine. What I ended up doing was sliding a screw driver behind the fan motor coming from under the engine and then stood on the front clip and pulled upward untill the plastic bent enough to clear the junk in there...... Bottom line you are going to sweat for it but once you knock the tabs off the edges man does it fit nicely to a jeep radiator.;)
Hmmm I really havent considered going with electric fans since most dont fit worth a :dung:. Thank you for the post now Im going to have to go to the junkyard for some fan action :chug:
Seriously do it. Tested it on the waggy today and stayed around 190. The controller kicked on both fans first though which I thought it wasn't supposed to do but whatever. I did however wire the second fan wrong so it was actually pushing air from the engine side out to the grill. So the fans were running oposite of one another and it was still keeping the engine cool.
As many know I've been making several posts and asking several questions about this upgrade and pending a delivery of those consarn 0.375/9.5mm female blade connectors today for that 70/80 amp relay I'll have all the parts I need.
I got the Mystique (Merc) fan for $38 clams (if I remember right)
4 relays relays and additional color code matched wiring was free (from the same car a couple of days later)
2 Hella 70-80amp sockets from Amazon $6 each
...and those pending oversized connectors that were so hard to find. (I'm intending on sharing them with anyone else that needs 'em they come in a bag of 50) $26 clams
I'm doing my own wiring using some diagrams found on this forum and elsewhere now that I got it straight in my head. This'll allow me to wire them up independantly for different startup temps and with and on or off override. I've got to take care of setting up my garage and then replacing a rear main seal first but once I get it underway I'm going to post step by step pics and text to help other neophytes with thick skulls like myself :D
For anyone who runs the AMC 258 i6 / 4.2l , a three row radiator, and dual v-belt pulleys, the 2002 up Contour/Mystique fan install isn't a walk in the park. Much trimming is required. No pre-2002 contour fans in my area, but my understanding is that the shroud/fan motor mounts are the same overall dimension in the possible problem areas.
The wiring is actually the easy part, and idle speed charging becomes a concern as well. If A lot of slow traffic or (crawling) off-road use is in your normal use, dual-batteries or a non SI Alternator are almost a must, IMHO.
Now a discussion on which fan to use as a primary fan ( s-blade driver side, or standard fan passenger), which way to install the shroud assembly (connecters up, or connecters down, this determines which fan is where) and some other seemingly minor details can make a HUGE difference on how this mod will work well for you. Each fan moves a different CFM, and draws different amperage.
Whether or not you use an auto tranny, tie in to the radiator cooler or not, and have an auxiliary cooler in front of your radiator also require some trial and error.
I have made most if not all of the errors possible (let's call it research instead), in the fine tuning of this setup. I'll try to get a photobucket account going the next few days, to post some pics of some of these difficulties, and how to overcome them, if anybody runs in to similar issues.
Till then, I'll answer any questions if my required setup, sounds like yours.
