Contour Dual Fan
Contour Dual Fan
The looms were intact, save for where the copper thieves adsconded with the pigtail of the harness. For the rest I just got some same sized loom and ran it to the Ford FDB I installed on the inner fender
"Ford FDB" to control it...??
I pulled back all the crappy bad wiring and ran 12 volts to each fan to check if they worked... Aside from that, I'm at square 1...
So, what's the verdict with this fan swap? I recently bought a dual fan for ford escort 2000 and it is 27" wide and just over 15" tall and appears to be a good combo swap but I'm having difficulty figuring out a frame to keep the plastic shroud from banging into the rad.
Were you able to mod or buy a metal shroud to work with your fan as I would prefer not to use plastic zippy things. ;)
$150.00
  75.0%
