depending on the route you want to go as far as where the distributor comes from, its as easy as removing all of your old stuff and dropping the hei in, hooking up your plug wires, getting a ignition switched 12v power source to the distributor, and then setting the timing.
you can buy a dist. from D.U.I. which is probably the best, but also the most expensive. you can get an hei distributor from an old chevy 250 inline six and put a amc v8 drive gear on it, or you can buy a china made hei which works decent in a pinch. i ran one of the cheapos for a while and i was pretty happy with it. then swapped it out for the tfi. matter of fact i still have the cheapo dist i will sell you if your interested in going that route.
