Coolant flush and radiator clean
Basod
Lifetime Supporter
Mt. Cheaha, AL
'84 CJ7, 258, T4, D300, D30, AMC20, 3.54 gears
Coolant flush was on the list and is planned for this weekend- expedited due my dumbass breaking the functional mechanical aftermarket sender line last weekend.
Going to pick up a Prestone flush kit- not my first rodeo there
But contemplating a muriatic flush as I have ample amounts for pool chemistry maintenance.
Planned on pulling the radiator as PO did not cover the grill prior to repaint- as an engineer with plenty of thermodynamics behind me the paint isn’t helping heat transfer. Jeep isn’t running hot but struggles a bit in traffic and I probably need a shroud to help with that- not sure which one I need this is an original 4cyl with 6cyl implant
So an MA exterior radiator cleaning with maybe a pre diluted cup of 31 Baum with water on the flush- thoughts?
NONE of the store bought stuff works as well as what the pros use.
You should also look at a 'rod-out' to the radiator.
When refilling, use distilled water with the AF.
If you don't have a shroud-Get one.....
Consider this process: Mercedes Citrus Flush
My 65 Mustang had a rusty sludge issue and no amount of prestone flush would get it out. This worked great and it has been relatively clean ever since.
+1 on the fan shroud.
I ran a 1/2cup of muriatic acid on a heat cycle then a round of CLR which worked better. After did a cycle of baking soda followed by two more flushes to ensure neutral pH.
Rinsed out a bunch of acorn shells and straw bits- radiator or block were open for a bit allowing rodent den in its past
FYI if you’re on a long term build cover your radiator and engine block holes
