coolant leak from passenger side hose
If it's just a hose leaking why don't you just replace it?
What is it that you are working on?
I ment what year and what motor do you have? Can't help when we don't know what you have.
Do you have the heater hoses hookup to your heater core?
You should have two hoses coing to your heater core one comes from the front of the motor and the other goes to the rear. I have the same Jeep so let my run out and look at it and then I can tell you where in the back it goes. But if it's like you say your heater must not be working.
Ok like I said one goes to the front of the head and the other goes to the back of the intake. Hope this helps.
Do you have AC?? Any chance it is the condensate drain? or the vent drain?
:cool:
One side of the rod hooks to the ignition switch that is mounted on the steering column and the other mounts up inside to pivot off the key lock cylinder.
