Interior Corbeau Low Back Suspension Seats
aglinks
Flagstaff, AZ
‘83 CJ7, 4.8L Vortec, TF999, D300, AMC20, D30
Hey all,
My driver seat is pretty worn out so I am thinking it is time to upgrade. Has anyone tried the Corbeau low back suspension seats? I have an 8" Tuffy console and am concerned they may be too wide.
Solution
I ended up getting a full set of Bestop seats. The fold and tumble rear seat from bestop really sold me. I am making brackets to use them with the Corbeau seat risers because I want a more secure seat mount and I want the seats to sit lower. I will post pictures when its done :)
I have a center console and the Corbeau Sport seats. They're a high back with head rests and recline. My seats fit just fine, even allowing the seat belts to still be in the loops on the sides of the console and I can move seats with ease. I believe the Baja's are 2.5" wider, so that would certainly be an issue. In addition, the Baja's have a standard width and an extra wide. So you could even get wider than that.
I've got those...like 'em a lot
Have a 50 mm ammo can for storage between them...no problem with fit
Never heard of a “50 mm ammo can”. Are you sure it isn’t 40 mm?
They make an ammo can for .50 cal, but never heard of 50mm either. .50 Cal Amo Can
Now the 40mm cans are quite popular. 40mm Ammo Can
The .50 cal cans are just shy of 6" wide (5.75" inside width). The 40mm cans are 6" wide. So both are narrower than most center consoles. So they would indeed work fine between these seats. The Tuffy consoles come in an 8" or 10". Since "aglinks" states he has the 8", perhaps "j6824" can tells us whether an 8" width console would fit since it looks like he has a 6" ammo can now with "no problem with fit".
That’s the most common, 40mm can. I have seen those used for a console numerous times.
My mistake...it's a 20
M548...14.5" x 8.25" x 18.5"
One of the aftermarket ones...no stencil on it
Solution
I think I’ve had my BT seats for 20 - 25 years maybe
I need to take some pictures in the daylight, but I used Corbeau brackets for the front seats and made some adapter plates out of 1/8x3” flat bar to make them work with the Bestop seats. The seats are the perfect height and angle! They sit ~2” lower than the factory bracket, so I’m nice and low with the new seats and won’t be hitting my head on the cage. IMG_2880.webp IMG_2888.webp IMG_2873.webp IMG_2874.webp
In hindsight I could have used a little thinner flat bar like you for the adapters instead of going full blast armor, I used full1/4" plates!
...because you never know when you might drive over a mine in the Canadian backcountry 🤣
:rofl: 1/4"! That's adding some seat ballist!
Interior Seat Covers
