Couple of problems changing the MTF
dagwoodzz
SE Louisiana
85 CJ V6 4SP
The Dana 300 drain plug is through one of the holes in the belly pan, look at the lowest point. It takes an allen wrench.
Thanks Old Dog - that was good information. The grease and muck had filled the recess on the plug. Once you told me what I needed to look for it went pretty quick. The oil in the Transfer Case was much cleaner with no water.
In addition I removed the fill plug to remove the excess fluid in the tranny. The new oil is already milky, not nearly as bad.
That amsoil is pretty steep, I hate to put it in the tranny if this next flush doesn't remove all the moisture.
Any ideas? If I flush a second time with cheap oil the cost is going to get close to whats already invested in the AmSoil.
Just an idea to get the bearings and gunk flushed out of the tranny.
Instead of oil use ATF. Fill with ATF, place Transfer Case in neutral, start the engine and run it through the gears a few times to get everything spinning and the fluid moving through the Transmission .
Repeat as needed.
    Best for votes
    on specific items
$70.00
  35.0%
