Cruise Control
Cruise Control
ThisGuyUKnow
Full Time Jeeper
Featured
Harleysville, PA
1986 CJ7 Laredo 4.0,Nv3550,D300 Twin Stick,AMC20 3.31, 31 BFG
Honda vtx1800c
Guys this is something that I will eventually document here but not for a while. I am just spitting this out into the world to see if I can get opinions....
There are a bunch of universal cc setups out there but they seem to run 100 for one that just adds buttons to the dash to 200+ for more stock looking ones.... So Eff that.
I recently fixed the CC in my GW(the PO cut the wires in the control lever for some reason only known to him and god) and I discovered that the CC in the GW is much like the Ac in Gws and cj/yjs in that it is an independent system that is basically bolted on. With that in mind I should be able to find a part out GW (if you know where one is let me know) and get the cruise stuff out of it and easily install it in the CJ. The biggest thing I have going for me in this is that I have a VSS in my cj that is an 8 pulse and as fate would have it the GW cruise control vss in the cable is and 8 pulse so it should be a matter of bolting the actuator to the fender drilling a small hole in the firewall to feed the harness through and splicing into the brake switch and the vss.... There may be an issue with the fact that the GW has a vac line that runs to a switch on the brake pedal under the brake light switch but i maybe able to wiggle around that if it will save me 100+ bucks. Only other issue is that the cj turn signal lever uses a screw to install where as the GW one just kinda sticks into the the column but I believe that the hn3 style gm cc levers which mount the same as the cj ones have the correct electrical connector to plug into the GW CC harness but I will have to get a hold of one to monkey around with it.
The best part about this is that if I pull it off the control box is stamped amc so it should look pretty stock.
Did any Cjs ever have CC? I am sure the Yjs saw it but have never seen a reference to such a cj.... Thoughts are appreciated thanks!:chug:
HEre are some shots of the CC stuff.
I have often thought about putting it in the J-10 but I am not sure I want to get that comfortable in the CJ5 . I do think it is an outstanding thought.:cool:
yep, CJs came with cruise control. It was mainly the later ones of course. I'm goint to add CC to mine as well. Tim, since your running an MPFI 6 based on the 91 to 95 YJ and XJ set up using the wiring and computer, why not use those CC and tie it into thier system. I'm using one out of an XJ and will just tie it into the GM controls. There is a short harness that goes through the steering wheel that is hard to find sometimes. The only change would be the CJ or GM style steering wheel collumn control lever. Heres a few CJ based pics. I've seen different set ups on the manifold bracket and servo placement though.
Ed,
Does the set up you are refering to run through the engine harness and ecm? Or is it a completely seperated harness like the waggy one? Also is the xj one motorized or Vac controlled? If it doesn't use Vac then I would be more inclined to go that route. Otherwise the wag set up is just easier to find as well as easy to get to(to remove)
It's about time u posted on this site BTW
What is model for this bolt on? I am looking for one for '90 YJ. Thanks If decently easy I may try to do myself:D
I'm looking for the speed control regulator with a 14 pin wire harness.. fits my 1984 CJ7 ... I have the servo and lever control, just missing the regulator and the wire plug.. thanks.. wayne
