Dana 44 Anamoly?
Looks like someone replaced your rear amc 20 with a 44, 84 CJ were no offered with a 44 axle. That would answer the larger brake question.
Yes, I understand that, however, I was under the impression that ALL CJs had 10 inch brakes
In the process of tearing down your wife’s Dana 44 to find 11” fined brakes is not an anomaly.In the process of rebuilding/ restoring my wife's 84 CJ7 I had to tear down the rear axle due to age and wear. Oddly, even though it's a wide track axle, it has 11 inch brakes with the finned drums....is this an anamoly?
I thought all CJ7's had 10 inch rear brakes.
and assorted junk. A Transmission filled with water and rust, axles with mismatched, rusty gears and botched lifted suspension. Now, 4 months later, its finished and ready for the body shell.STD for the 44 use.
Your '84 was a PO change over.
Can you post some pictures?
