Dana 60s
Dana 60s
Peanut Butter
Full Time Jeeper
Boerne, Texas
It don' t look as big as I thought it would in front. It seems like the Power-loks are plentiful for the Dana 60. I saw one on CL not too long ago that was built for a CJ rear. It was a high pinion front housing with a 30 spline power-lok with CJ Dana 44 tubes and axle shafts. I just wonder how much ground clearance you would give up.
I read that you give up 1" of clearance with the D60
I have seen the bottom of the pumkin on the D60 shaved for more ground clearance. After once having a front powerlock, I was quite disapointed and now have an ARB. The D60 could support some serious tires though.
Holy :dung: :dung: Posi, that is awesome! :rock:
I hadn't really thought about the ground clearance difference using a Dana 60 over a Dana 44 . However, I think the ability to add even larger tires would compensate a little for that.
Posi, looks like you are going to keep the 8 lug bolt pattern. In which case you just cut the axle down and have it resplined, if I understand correctly. I'm guessing you would need a custom axle if you wanted the 5x5.5 as in this case. Thinking out loud, the 8 lug pattern would be stronger, but the custom axle and mimic the same bolt pattern would look more original. What size wheel (diameter) will you use with yours, Posi? When you get into the really large tire sizes, 37 to 44, does it mater? :rolleyes:
I'm thinking with the Dana 60 conversion you would need at least a V8. :eek: Don't think the I6 would have enough torque or horse power, or am I wrong?
One more question, Posi, why the Chevy D60 front and not the Dodge since you are using the Dodge D60 in the rear?
By the way, nice welding skills.:notworthy:
That's correct.
Yes, the 8 lug is much stronger.
The only reason I would swap to 5 lug would be to match rims that I already had and preferred using, although it would be less expensive and time consuming to buy new rims. I also wouldn’t go with a large tire (over 37"), or do any heavy wheeling, there is a reason they come stock with 8 lug.
The 5 lug will give the look of original from the sides but from the front and rear there is no mistaking the beef of 60s compared to a 30/20.
The thing your dealing with on a 5 lug swap is the hubs. There are a few vendors who sell front hubs for the 5x5.5 swap. You can do it yourself by turning down the D60 hubs to fit through the 5 lug rims, turn the backsides down to fit the 5 lug rotors, and then re-drill the flanges. You would need to make a caliper bracket to fit as well. There are multiple ways you can do the swap using D-60, Dana 44 chevy, and ford parts as well.
The rear 60 full float (FF) could be done if you wanted to keep it, but it would be time better spent going with semi float 60 and converting to 5 lug. There is the J-20 rear SF 60 35 spline that already has the 5 lug but the pinion is off centered a bit, not a big deal.
I'm running H2 17” rims with 39.5 PB. I found most tires brands 37” and under do not live up to their advertized size. I had a friend measure his 37” Pitbull and they were around 35”, and smaller when he aired down. I have also found tires over 37” are more true to the advertized size.
Although I run a 360 there is no need for a V8, the AMC 258 i6 / 4.2l is plenty of engine to run 60's and large tires if geared correctly.
The chevy has the better internal hubs and the dodge has the external hubs. I went with the dodge rear because it was a HD diff with extra webbing and is smaller in size then the 14. My plan was to run 37” tires but couldn't find one that actually measure 37”, plus I got the 39.5 at a great price as I previously mentioned.
Is the end of the tube that is inside the knuckle welded? :rolleyes: Can it be removed? Seems like that would be the best solution, but I'm clueless since I have never attempted any of this. :dunno: Would it be worth getting a new knuckle to weld to the tube?
Yes, to the weld, and no to the new inner knuckle or (C).
See my previous post.
could you have punched/pressed the tube out without cutting it?? how did you cut it? Who made the replacement axle shaft?? was there an option of cutting and re splineing the old shaft??:cool:
You would need to grind down the weld between the tube and C to press it out. Removing the weld while the tube is still in would be tedious and most likely gouge up the C in the process. Much easier to grind down the weld without the tube.
The tube is easily removed by making three cuts to relieve the pressure then tap out the pieces.
how did you cut it?
Band saw for the tube, angle grinder with a thin cutting wheel for the axle shafts. You could use a chop saw for the tube as well. I used a sawzall to make three cuts to remove the tube.
c Who made the replacement axle shaft?? was there an option of cutting and re splineing the old shaft??:cool:
The front shafts I subbed out, had them cut down and re-spline my original shafts. I paid $125 for two ( I had a spare). I believe it cost $90 for one so it made sense to cut and respline two.
Mitchell Differential Custom Axles and Differentials |
The rear, I purchased 1.5 35 spline shafts with extra long 6” splines so I could cut them down for a custom fit.
I've also cut down front 44s as well.
More questions, what did you use for springs and did the Saginaw steering box from the CJ work out OK?
I was also curious about the steering setup you will use with this too. Is stock strong enough?
That was great Posi! Thanks for the step by step and all the pictures. Now to dream and keep one eye open for all the right parts.:D
My pleasure, and thank you for the kind words.
TCase Dana 20
