Dedicated gauge grounds
shum8
Voted most irritating
Gold Supporter
Roanoke, Va
'80 CJ-7, AMC 304, T177, Dana 300, Widetrack axles (D30 & AMC20) w/ 3.73 gearing, MSD ignition,
Ok - I am in the process of running a dedicated ground bus throughout the chassis. Have mounted a ground block under the tailgate for the rear grounds, and will be adding blocks under the dash and on the firewall. My question is specifically for the Temp and Fuel gauge grounds. They usually ground thru the speedo case, but I would like to ground them to the ground block as well. Should I just leave em grounded to the speedo case or would it be better to ground them to the ground block? If so, where should I tie into the gauges? everything else is pretty straightforward, but these two have me scratching my head.
Rob
When I redid mine not too long ago I ran a bus bar, too...ran a ring terminal off one of the speedo mounting studs to the bus bar...just to be sure
The CJ should already have a ground wire from the negative battery post to the firewall. You could extend this to the dashboard to improve the ground connection on all the circuts that use the dash.
I agree - but I wonder if I should individually ground the fuel and temp gauges?
The fuel and temp gauges are grounded at the dash where it is screwed on. Providing there is a good ground at the firewall, adding additional wiring will not hurt. This could be checked with a multimeter. Adding those serrated lockwashers will help here. Other weak points on the CJ would be the frame ground on the gas gauge send unit, the ignition control module, and the windshield wiper motor. The highest amp draw would be the starter motor and adding a ground wire to the alternator housing won't hurt. Anywhere the CJ uses the poorly conductive steel for an electrical connection could use some help.
Ah HAH - I get it now..... and it makes perfect sense.. I forgot about the temp sender and fuel sending unit grounds...... Man, looking at the gauge and trying to figure out where the ground path was kicked my buttocks LOL.
I will also be welding a couple studs to the backside of the dash for a ground point that ties into the ground bus. By the time I get this thing done (if I live long enough) it'll have grounds if nothing else.
Thanks for the explanation...... I feel smarter now :chug:
I would suggest you run a dedicated GND wire from the dash's panel to the battery NEG(-)post.
Coat the connectors with battery terminal spray to maintain full conductivity.
Currect engine temp and fuel tank readings depend on a good dash GND.
:ty: Your pictures are outstanding.
Know'n how to solder is a lost art these dayz. :notworthy:
I learned while building radios.
Thanky, Sir -
I don't have a problem with soldering - it's finding the lead solder than can be challenging..... I now have a stash that would probly get me thru 3 or 4 rebuilds :chug:
Yup, finding true 60/40 rosin core is all but impossible in PRK.
Have my inlaws ship it to me:D
You could just mount the GND on the speedo to one of the speedo mounting studs.
For GND connections, I recommend the use of external star washers as they 'bite' into the surface. When done-Coat all GND connections with battery terminal spray.
Electrical Gauge tester
