Differential cover ?
sandtoy
Delco PA
Afternoon all: hoping the weekend works out for you whatever you have planned
Want to change diff fluids this weekend. (1986 CJ7 ) Quadratec shows gaskets for both the front 30 and the rear 20.
Question: are these gaskets needed or will a good coat of RTV work?
What is your opinions???
On my JK it was recommended not to use a gasket but that was using aftermarket covers not O.E. although when I removed the O.E. there was no gasket on there.
thanks for the input
Front is a Dana 30 . I use gaskets myself. I was going to try those lube locker gaskets next that are supposed to be reusable.
I use a gasket with rtv on both sides. I guess I like to make sure it doesn't leak but that's just me.
My Jeep has enough other leaks :D
I do the same, gaskets with a very, very thin layer of RVT.
i run a bead of rtv around the covor and bolt holes and slap her on. never had a problem. i used to work on a racecar and it lived off rtv.:eek:
