Differential gear pattern?
HH-As I 'read' this latest pattern. You have to much 'toe' contact on the drive side of the ring gear.
Now that you have seated the pinion bearing race I feel the pinion is to deep.
I would 'back out' the pinion .004" and take a read.
We may very well have to bring the ring gear inboard some.
Do only one adjustment at a time-
Hang in there, you'll get'er done.
Thanks, in my write up I did skip all the little adjustments that got me to where we are today. I'll adjust the pinion, I don't know if I have a shim for 0.004, I've got 0.0025" and 0.005". But Rob gave me about 200 shims to work with, there might be a thin one in there somewhere.
Then I'll reset the back lash if needed. I am finding myself going back and forth between the same shims and it seems to be settling on just a few adjustments.
There is some relief in getting an actual readable pattern, it feels like real progress.
If you have a .005-.006 to pull. That's fine. You want the drive side pattern more to the middle/center of the teeth.
Look again at the examples I posted for you.
Pretty sure we will need to move the carrier to the ring gear some.
HH-IIRC, these were 'used' gears. Correct??
That 'spreader' you have in the picture isn't under strain when your taking the pattern read is it? Hope not--
If that is the case. Your pattern is good.
Double ck all your bolts/nuts for correct torque.
Ck your pattern in 2 places along with the BL.
But these are used gears and the articles I read say used gears are different from new gears. Just to get it out of the way, the case spreader is backed off, the cap's have been tightened down, the pinion is set with the proper preload.
So, Lumpy ( and others) what do you think I should do next?
Lumpy - I knew you were going to ask that question. I'm learning how closely.. (nope I'm not going to go there).. :) So we are good! oh yeah I've been waiting for that and will do the tightening double check. Now for the Dana 44 , but honestly after this exercise I think I've got it figured out. Couldn't have gotten here without the help. Thank you!
I hope this helps someone who is going through this process. One thing I learned is to use a proper Gear Marking Compound. The stuff is simply different, very different .... and I will likely be cleaning it off tools and other surfaces for weeks.
Button it up and fill'er with oil.
Drive side looks good. :notworthy:
Let me see the coast side--
How much B/L are you run'n?
BTW-that's .003, not .0003 :D
And by god the back lash is a decent "0.007".
The coast pattern is great, you actually can see it in the two yellow teeth to the left. The sun was all wrong and I couldn't get a decent picture. Also the marking compound was cold and just couldn't get it thin enough for a great read, but trust me, the pattern is very good. It actually shocked me a bit to get it right off the bat like I did. I've gone out several times to recheck the pattern and it still looks good.
Again, these are used gears and I studied the original wear on both the pinion and the ring gear. What I'm getting now looks good for any pattern and is all but identical to the original wear pattern. There does appear to be a science to this.
I was surprised about one thing. The Dana 44 diff. housing is very soft. The spreader took much less strain to open the case. Also, the E-locker required a 1/2" hole to be drilled in the case. The case drilled like the proverbial butter. With the reputation of a Dana 44 I expected much more of a struggle.
Yeah I'm always dropping an extra "0" in these measurements. I know what I'm reading, but it's never good to write a mistake like that.
Then add oil, and drive it. :D
