Doing a TeamRush Upgrade.
kicknjeep
Old Time Jeeper
Lebanon,Tn
1999 TJ, 1976 CJ-5 2 seater
Re: ignition control module
You should be good to pull the dist, just put the new one back in the same orientation, don't turn the engine over after you pull the dist.
OK overall have distributor in with Teamrush ingredients added and it actually starts but I am still having timing (I thinks it's the timing)issues. It will start, run and idle fine but it has a serious drag when starting kinda like over advanced. can somebody post a picture of there distributor w/out the cap with TDC and rotor pointing at the # 1 to make sure it's correct. This is for an AMC 304 V8, I am almost there :cool:
OK it is to where it turns a few times but it starts pretty good and revs great, BUT I am thinking the carb may need rebuilding mostly because well it looks like it could use it. second it has a slight hesitation when you hit the throttle. Don't know maybe just too used to throttle bodies. Anyway it is 200% better in all. Thanks TR and everybody for their help...
The 'Hesitation' when you 'Take Off'....
If it does it MUCH worse from a standing start, it's probably not enough accelerator pump shot.
The accelerator pump... Fuel shot... Is adjustable in virtually ALL carbs, and it's a good idea if you RICHEN up your pump shot to see if the problem lesses or goes away.
Your 'hard starting' problem, especially when hot, can be minimized by reducing your INITIAL TIMING SETTING.
Back the Initial timing down to about 6 degrees before TDC, and that should help a bunch when cranking.
See, your factory DuraSpark module had a 'Start' circuit in it that retarded timing when the engine was cranking, trying to start...
Usually from 8 to 12 degrees to make it easier to start when the engine was warm, or very cold.
The HEI module DOES NOT have that timing retard circuit in it, so it's making your engine difficult to start with a lot of initial timing.
TR actually haven't driven it yet due to doing interior body work and lack of seating, I was referring to initial start up and it actually has little to no drag anymore upon warm start-up. Just have the little bugs to work out and it is going to kick buttocks :D. Now back to grinding welds so I can primer the inside tub to get it ready for a liner....
OMG starting to sound like the 'ol lady :laugh::laugh:
Hey rush would you happen to know where the brake booster vacuum hose connects to the AMC 304 V8?
mine is hooked to a valve on the manifold behind the oil filler and when I try to hook the vacuum from this valve to the dist it kills the motor
( both are on a valve of sorts are from this area).
Wait...your hooking the distributor vacuum advance line to full manifold vacuum?
That is supposed to be hooked to ported vacuum supply off the carb, dude. your advancing the distributor full on, thats why it kills the motor!
~~~Hey rush would you happen to know where the brake booster vacuum hose connects to the 304 V8?~~~
It should be hooked to a large port directly to the manifold under the carb.
OK here's where I'm at, I have the distributor hooked to the vacuum port on the right bottom of the carb!, now I am reading ( and per CJ) that the brake booster goes to the port on the back of the carb, Is this right? where would the PVC plug into?. Any pics would be helpful. Oh and when I changed the distributor vacuum line out it smoothed out the idle a bit :D
$190.00
  95.0%
