door doesnt align.
door doesnt align.
SkippyCJ
Upper NJ
1985 cj7 fully stock with a straight 6 but missing some parts here or there
hey everyone.
its getting pretty cold out and my driver side door does not align with the the surrounding frame but still closes. their is a gap between the door and the front window and don't really want snow to start to find its way in. any suggestions?
i am also brand new into Jeeping so help in any way is appreciated
beetween the door and the windshield?
yes
do you have a hardtop on?
yes i do.
am i going to have to loosen the bolts on both sides of the windshield? the passenger side door aligns up fine
There is a big BUT in all of this. Does your door align properly on the bottom, or just the angle of the windshield?
it does not align on the bottom either. the door still closes if you give it a little push
hey guys. i got the door pretty close to fitting perfect. It is a lot better than it was before and no snow will be able to get in :D
the lower hinge on the jeep is bent open a little bit so the door wont close all the way with out hitting the frame. im hoping to get new hinges soon though!
It is a lot better than it was before and no snow will be able to get in..
Any chance you could post up some pics?
here are some pictures for you. hope they help
I have this same problem with mine, but, I was in a hurry... even so, my approach was to align the doors to the tub first, which I did, and the gap is even worse on at the windshield. It doesn't seem like I can pull the windshield back any farther, the gaskets are soo thick, it seems like it'll break off if I try, not to mention my top seems to fit the top of the windshield like it is and it would be futile...
A hinge bent that much will throw a door way off!
