Doors
Doors
oilfieldhand
Quitman, MS
1976 CJ7 304 Quadra-trac TH400
Ok I have tried to search it but no luck. Were can I find parts to fix my doors? PO put in a wedge on the drivers side to hold up the window.:mad:
have you taken it apart far enough to find out why it doesn't work?? Whats broken?:cool:
you may get lucky and find you just need a little epoxy or a rivet.:D
Had the same problem with mine from the PO. Took it apart and found the regulator arm twisted like a pretzel. Hammered it straight on a vise and put it back together. Works great.
