Misc Drive shaft angle/Rough County Suspension
Genaz
Silver Supporter
Easley, SC
1979 CJ7. 258cu 6cyl. T5 tranny/Dana 300 transfer case (both from '82 Scramber)
Hi. I installed a Rough Country 2.5" lift kit in my '79 CJ7 . Despite the instructions, and original set up, it would not go in axle-over-spring. The front shocks were completely compressed, and sway bar links were too short. So, disassembled and installed spring-over-axle and everything fit fine. However, now my rear drive shaft is at an extreme angle. Rough Country recommended flipping the shims 180 degrees, but that didn't help. I'm pretty frustrated at this point. Does anyone have any suggestions? Do the shims maybe have to be switched to the bottom of the leaf spring?
I notice that some of these spring plates have one stud and some have two studs. Is that one for shock and one for sway bar link? Any idea which one I'll need before i start tearing this down again?
PS: Thanks again for all the input from everyone. It's been invaluable.
No, it has about a 7.5" bolt or I made a stud at one point when originally installed AOS. I'll get a picture to you later when I get home.
Well, if it doesn't look like the 2nd image it's not stock. Your pictures will help.
Thanks.
The rear spring plates have the single stud for the shock. The front spring plates have two studs, one for the shock and one for the sway bar links. Your earlier pics showed a different sway bar and links that are not stock CJ style.
Started the tear down again. So, I can just cut off these top spring perches and toss them, correct?
Before you do that can you really take a boatload of pictures so we know what we are dealing with.
Thanks for your help again. I'm actually flying out of town to spend Father's Day with my daughter today. I'll get new pictures when I get back next Friday. Have a great Father's Day everyone.
Sorry for the delay in response to everyone. Traveling for work and haven't had a chance to get back to the CJ and this nightmare. I've got a long weekend for the 4th of July and will get back to this then.
Thanks very much for the pics. Completely different than the 2.5" I'm installing.
Does anyone have specs or illustrations of where the original shock mounts would need to be moved to? I'll get some more pictures of the existing set up when I get back to it.
Thanks for the help.
Glad to hear you're getting back to this.
We will find some measurements for you.
WOW! Definetly SOA. Where do you live? I'll do it fo you. I'm in Tn.
That looks so much better. I see the wedges on the rear axle to tip the pinion angle up a bit, helping rear drive shaft angle. I see the sway bar and proper connects (dog bones). And the tie rod and drag link look nearly parallel as they should be to avoid bump steer. Should be driving like a dream now.
$20.00
  10.0%
