Drivetrain question
Drivetrain question
jeep cj7 304
Colorado Springs
Okay, which is better, a Dana 20 or an np208? I am planning on switching my Transmission for a t19 with the 6.32:1 gearing and it comes with the np208, but I don't know if I should rebuild it or stay with my already rebuilt dana 20. Oh, and I will also be putting in scout axles soon as they are sitting in my garage and I am tired of narrow track axles that are about to break. So stay tuned for a build thread soon.
Okay, which is better, a dana 20 or an np208? I am planning on switching my transmission for a t19 with the 6.32:1 gearing and it comes with the np208, but I don't know if I should rebuild it or stay with my already rebuilt dana 20. Oh, and I will also be putting in scout axles soon as they are sitting in my garage and I am tired of narrow track axles that are about to break. So stay tuned for a build thread soon.
IMHO the Dana 20 would be superior. I personally prefer the all gear drive to chain drive & the steel case vs. aluminum. However the NP208 has a lower reduction ratio.
I am not afraid of chain drives or aluminum, but I will say the Dana 20 is a very nice case, you can get a low low kit for it and it is one of the narrowest cases out there making for a very short drivetrain, which in a cheap is very desirable.
NP205 was the all gear driven unit if i'm not mistaken.
But of the Dana 20 or NP208, I'd choose the dana 20, it strong and is an easy rebuild.
But of the dana 20 or NP208, I'd choose the dana 20, it strong and is an easy rebuild.
Dana 18
Dana 20
Dana 300 are all three all gear units.
The New Process 200, 205 are also all gear.
My favorite stock case is the NP231
chain and Aluminum but it has a ton of aftermarket support, probably more than any other case, and I have beat a few all over the place and never had an issue, one I am running 4 to 1 gears in,
Of the 5 cast iron one mentioned here I like the Dana 20 and Dana 300 best. I do run 2 jeeps with the D18 and know every single issue it has, it may be cast and geared, but because of the double offset output it has bearing trouble. I live with the fact it needs a bit more care.
Running CJ5s, I like the D20 over the D300 because of the fact I can get a shorter drive train using it. After those Like I said I just jump up to the NP231 because of the support and my experience with them.
Those are my reasons.
    Best for votes
    on specific items
