Does it matter which drum goes on the rear? The new one piece axle hubs don't have the the extra threaded holes. I'm switching the front to disc and was going to clean up the best two for the rear.
As long as they slip on the axle, are the correct diameter, width and the offset distance from the mounting surface to the shoe surface is the same you can use them.
