Engine EGR help!!
Engine EGR help!!
ScramblerCO
Centennial, CO, USA
1982 Jeep Cj-8 Scrambler
258 4.2L I6
Appreciate the help Admin!
So I was told I need to pass emissions to get plates, I failed big time with my carb system. With no ERG, will that affect it?
The red arrow had my CTO valve attached to it. Should I just run that to my brake booster?
And yeah that is an old O2 sensor which wasn’t plugged into anything. Unsure on its history. I’ll replace it with my new system!
Do you have any friends or family that live in a county that does not require testing? It may be less hassle to take up temporary residence if so ;)
Scrambler,
Sorry, but you’ll likely need to pass the visual and sniffer test. I’m just down the road from you in Castle Rock and had to comply when I installed Howell on my ‘86.
Howell makes a CA approved type kit, which I used and passed the test with. CO adopted CA’s restrictions.
Do you have this version from Howell?
Scrambler,
Ouch, I had a feeling that would be the case. Clifford non EGR intake will not fly... :(
Trans 81 CJ8
