Engine 304 Intake vacuum port identification
Tim_Coble
Donator
Alabama
76 CJ5, 304, T150, D20, AMC20, D30
Solution
EGR is correct.
PCV is correct.
Exhaust back pressure sensor is correct.
1 = Full manifold vacuum port, usually used with a factory air pump and spark control switch. Cap it off if not used/needed.
2 = Temp gauge sensor.
3 & 4 = Choke heater (could have a cover plate if not used/needed).
5 = Another full manifold vacuum port (could be used for power brake booster if not using a lower port on the rear of your carb). Cap it off if not used/needed.
Solution
Awesome, thank you!
So, distributor gets it vacuum from the carb? Interesting. Wish my manual had a nifty diagram like that.
Yes - in the stock setup, the distributor gets ported vacuum from the carb, not full/constant vacuum from manifold. However, you should consider either as an option, depending on engine setup and desired outcomes. Here is the main rule-of-thumb:
Manifold Vacuum:
Better idling and low-speed performance
Improved fuel economy
Better throttle response
Ported Vacuum:
Reduced emissions
Improved high-speed performance
Minimized risk of engine overheating
I have usually chosen ported vacuum so that timing was adjusted based on the throttle position.
Here's a quick side-by-side chart for reference:
ParameterManifold VacuumPorted Vacuum
Vacuum at IdleHighLow
Vacuum with Throttle OpenIncreasesIncreases
Timing AdvancementSteadyThrottle-dependent
