• The site may intermittenly be closed or unreachable due database issues and the gallery / downloads are currently offline. Sorry for the inconvience.
Electric Fan(s)
Electric Fan(s)
Whenever you find the power source you want, run it to a distribution block on firewall for future uses.
I have two positive blocks on mine. One switched the other battery. Makes adding things later SO much easier.
I have been meaning to do this. How do you create the switched one? How does it get the power only when ignition is switched on?
Well I got lucky in that 77 and earlier the switched power stays on throughout the cranking process. I think in 78 on you have to draw from a source in fuse box.
I wonder if the line going to the ignition box is the best one to use?
I wish I could tell you more but once you find that wire/circuit you just run it to the block and that’s it. Then anything grounded and wired to that block gets power at key. Adding a similar ground block or two is important as well.
Makes wiring projects and cleanups SO much easier.
Thanks. I was wondering if it was just running off of the fuse box.
And yeah, I have a ground block already. Needed that early on having a glass tub.
Good deal. Well a little trial and error and you should be good to go. Best of luck to you.
The older panel for my ele fan has a replaceable relay.
I now see the newer ones do not.
How do I? Oil seal
$210.00
  100.0%
