Electrical problem.
Electrical problem.
wariochavez
El Paso, Tx
1975 CJ5
Hey guys hopefully some one can help me out, by the way i'm new at this.
I installed LED lights for front and rear turn signals, now the problem that i have is that the turn signals don't work, they light up when i turn them on and stay on but don't flash. the same thing happens with the emergency flashers. I replaced both the flasher relay and turn signal relay. Any help would be greatly appreciated. Thanks.
you will need a solid state flasher. the old flasher operates on the current that the incandescent bulbs use.The LEDs use very low current.:D
Should be one for each flasher relay shown in the schematic. Make sure the ground connections are clean and tight. We've had low current type devices at work actually stay energized because a power cord ran close by.
Well happy to let you guys know that the solid state flasher worked awesome just plugged it in and it worked now my turn signals and hazards work great thanks to everyone for their input.
