Electrical relay
The wire colors and red, red (white trace) and brown.
They lead to an electrical encasing tube, and that tube leads to the fuse box. However there is a series of wires that split off from that tube (before the fuse box) and into a harness than is plugged into another set of wires that lead no another encasing tube that split off into another set of wires, and so and and so on.
I have the service manual but it is no help.
Boy they really went nuts with the emissions setup for these years.
I have a hunch that this 'relay' thing is somehow related to the problem with the electric choke. I might supply straight 12v connection to the choke housing to see if that works.
Check this:
"The electric choke sticks out on the right side of the carburetor, and has red-with-white-tracer wires plugged into it. It's operation is straight ahead. When the engine is started, the electric heating element is energized through a relay tied to the oil pressure switch, gradually opening the choke."
(attachment image pulled from FSM... indicates the wiring colors, identical to the 'mystery relay')
I wonder if this is the choke relay. (not to discount your suggestion about the manifold heater relay, just thought i'd throw it out there as well)
A
Maybe it was a California Jeep versus yours or 4 banger versus 6 or where it was made.Who knowsthis is really weird my jeep was bone stock when i got it and it didn't have anything that looked even remotely close to this. yours is the same year as mine.
