engine knock
engine knock
g1159boy
Wisconsin
46 cj2a, 48cj2a, 94yj
Hello all, I let my nephew drive the CJ2a and he brought it back with a bad knock.
checked compression..... good
checked valves, valve springs, tappet clearance..... good.
pulled oil pan and performed basic inspection........ good
here is a YouTube link to my sick engine. cj2a engine knock - YouTube
Any help is appreciated.
Thank you
Sounds like a rod knock to me. You need to pull the pan and check the rod bearing. And I would not be running it any more you are just making it worse.
X2 'rod' knock.-Don't drive it!!
What story did the kid give you as you shoveled the dirt on top of him? :eek:
Lets just say that I was a little angry.
Rod Bearings appear to be the winner. I will pull the pan this morning to inspect further.
How about shorting the plug while running to determine the bad bearing? Bad /good idea?
thanks for the replys
DP
DP
idk about shorting it, i would pull the wire while its off and chase it that way, should only take three short tries.
Stop run'n the engine-Tear down time.
Make the kid help you!
# 4 rod bearing was bad. thanks for the advice.
Next question. is there any way for me to check that the rod bearings are getting oil? I have 30 to 40 psi oil pressure.
If they ain't get'n oil. They'll look burnt and scared.
So-What story did the kid give you about the WHY of the noise?
Id say at the very least you have a parts washer..
