Engine Swap Questions (before I begin)
Coach
- Dallas, TX
- 1986 CJ7 / 4.2 I-6 / Auto / Dana 30 / Dana 300 / AMC 20 / Hard Top
I have an '86 CJ7 that is basically bone stock and the specs are listed to the left. I have a few questions and I'm sure you guys will be able to answer for me. Some may seem obvious, but I have had a lot of time on my hands today and I made a list of a few of the things I'm not sure about.
What is the best way to store both the engine I plan to swap in and the engine I'm taking out of my jeep? Can they be left on the floor of the garage, make a pallet to support them on, or do they require an engine stand? AMC 258 i6 / 4.2l out and Chevy 350 TBI in.
I'm pulling the AMC 258 i6 / 4.2l that has just over 100,000 miles on it and the TF999 Transmission , is Craigs list the best way to go about selling them off? I will search locally to see what the market is on pricing them.
My CJ has AC, would the compressor from the 350 be compatible with my AC system in the cab or would I need to do some swapping to get it to work?
Fuel Pump, with TBI I will need to increase pressure, so is in tank an option? Would it be better to get an external pump that has a built in reservoir and place it near the tank? Do I pull the stock pump out of the tank if I use an external pump?
Thats about it. I know some of these are random questions, but I'm trying to do as much up front research as I can to reduce wasted time and money once I get under way.
Thanks,
Coach
Thanks,
Coach
