Engine Variants and Types in CJ's (53-86)
Featured
This list is being compiled and is not yet complete.
6 Cyl. Engines
258 (4.2 Liter) I6 (1972 - 1978)
Compression - 8.0:1
Horsepower - 110
Torque - 195
Bore x Stroke - 3.75" x 3.9"
Fuel Delivery - 1 bbl Carburetor
258 (4.2 Liter) I6 (1979 - 1981)
Compression - 8.3:1
Horsepower - 110
Torque - 195
Fuel Delivery - 1 & 2 bbl Carburetor
258 (4.2 Liter) I6 (1982 - 1986)
Compression - 9.2:1
Horsepower - 115
Torque - 210
Fuel Delivery - 2 bbl Throttle Body
8 Cyl. Engines
304 (5 Liter) V8 (1972 - 1978)
Compression - 8.4:1
Horsepower - AMC 150
Torque - 245
Bore x Stroke - 3.75" x 3.44"
Fuel Delivery - 2 bbl Carburetor
304 (5 Liter) V8 (1979)
Compression - 8.4:1
Horsepower - 130
Torque - 245
304 (5 Liter) V8 (1980 - 1981)
Compression - 8.4:1
Horsepower - 125
Torque - 220
most amazing information about this Engine Variants and Types in CJ's (53-86) i have ever seen nice job done dude
i will read it carefully
I just bought a 80 CJ5 with the 4cyl. engine. It came with a Rochester Varajet #17080781. The engine was taken apart. I have since got it running, but need a picture of a stock cj with the carb hooked up so I can figure where everything goes. This is a Ca. car. Can anyone help me? I am desparate. Thanks in advance.
oh you forgot the 65 thru 71 Dauntless Buick 225 V6 V6
155 HP and 235 pounds of torque
2 barrell
2.75 x 3.4
9 to 1 compression ratio
And what about my 64 3B's 4-134 rated at 75HP?
The '76-'77 AMC 304 was 120HP 220ft-lb, the '78 was 130HP 238ft-lb, the '79-'81 was 125HP 220ft-lb.
The 134ci 4cyl started out as an L-head (valves in head) and than the F-head, the two intake valves in head and the two exhaust valves still in the block. Bore is 3 1/8, Stroke is 4 3/8. Blocks were the same, Head were different between the L and F heads, as i recall.
I think you twistwed it up a bit... The L head(L134 "Go Devil" ) had it's valves in the block and the F head(Huricane) had it's intake valves in the head and it's exhaust in the block.
The L head produced 60 HP
The F head 72-75 HP.
MB-GPW
1941/1945 134 L HEAD CAST # 463
T-84 TRANS/DANA 18 TRANSFER CASE
DANA 25 FRONT AXLE/DANA 27 REAR AXLE
4:88 GEAR RATIO
2 PIECE WINDSHIELD
6 VOLT SYSTEM
NO TAILGATE
CJ 2 A
LATE:1945/1949 134 L HEAD CAST # 463
T-90 TRANS/DANA 18 TRANSFER CASE
DANA 25 FRONT AXLE/DANA 41 REAR AXLE
5:38 GEAR RATIO
2 PIECE SPLIT WINSHIELD
6 VOLT SYSTEM
TAILGATE
CJ 3 A
1949/1953 134 L HEAD CAST # 463
4:88/5:38 GEAR RATIO
1 PIECE WINDSHIELD WITH CENTER VENT
6 VOLT SYSTEM
TAILGATE
M 38
1950/1952 134 L HEAD CAST # 463
DANA 25 FRONT AXLE/DANA 44 REAR AXLE
1 PIECE WINDSHIELD
24 VOLT SYSTEM
EARLY MODEL JEEPSTER VJ 2WD
1948/1949 134 L HEAD CAST # 463
1948/1949 148 L HEAD CAST # 663
1950/1951 134 F HEAD CAST # 473
1950/1951 161 L HEAD CAST # 673
T-96 TRANS WITH OPTIONAL OVERDRIVE
PLANAR SUSPENSION WITH 1L/1R FRONT LEAF SPRING
SOLID FRONT AXLE
DANA 23 REAR AXLE
6 VOLT SYSTEM
LATE MODEL JEEPSTER C101
1965/1971 134 F HEAD CAST # 473
1965/1973 V-6 225 DAUNTLESS MOTOR
T-14 / T-15 / T-18 / T86AA TRANS
DANA 18 OR DANA 20 TRANSFER CASE
DANA 27 FRONT AXLE OR DANA 30 FRONT AXLE
DANA 44 REAR AXLE (TAPERED OR FLANGED
12 VOLT SYSTEM
CJ 3 B
1953/1964 134 F HEAD CAST # 473
5:38 GEAR RATIO
1 PIECE WINDSHIELD
6 OR 12 VOLT SYSTEM
CJ 5
1955/1971 134 F HEAD CAST #473 OR CAST # 475
1966/1971 V-6 225 DAUNTLESS MOTOR
T-90 TRANS/T 18 TRANSFER CASE
1952/1960 DANA 25 FRONT AXLE
1961/1971 DANA 27 FRONT AXLE
ALL YEARS HAD THE DANA 44 REAR AXLE
1 PIECE WINDSHIELD
6 OR 12 VOLT SYSTEM
CJ 6
1955/1966 134 F HEAD CAST # 473
T-90 TRANS/DANA 18 TRAFER CASE
1955/1960 DANA 25 FRONT AXLE
1 PIECE WINDSHIELD
6 OR 12 VOLT SYSTEM
M38-A1
1952/1971 134 F HEAD CAST # 475
CAME WITH CHOICE OF A 1 PIECE WINDSHIELD
OR A 2 PIECE WINDSHIELD
24 VOLT SYSTEM
:oops:
I stand corrected, Thanks.My typing got ahead of my brain.
