Ever BROKE This?
RedDog
- Media
- 11
- Canton, TX
- 1982 CJ7 - Stock until my pocket gets bigger!
258 I6, T4 Trans, D300 Transfer, AMC 20, Dana 30.
Had bad motor and trans mounts.... changed them out a couple of weeks ago.
Everything has been fine, then the other day I went to shift gears and the shifter was in my hand.... not connected anymore!
Not sure really what to call it.... the shifter goes down through the boot, then into this mounting plate? then is bolted to the top of the transmission...
(1) What is this called? I have searched all over the web, cannot find this part anywhere.
(2) Can I just have it welded back up?
Also noticed that it had two bolts holding it down on the front, two in the middle and one on the back... the back one was broke off.... I am thinking that the back on was already broken due to the bad mounts it got stressed over time and cracked the mounting plate and then finally broke. But I haven’t ever seen anything like this and hoping somebody could give me some insight if this very well could be the case, or do you think it all came apart at once?
also in my Info... I think i have T176 listed as Transmission, well after doing research today, I am pretty sure it is T4 instead, I will update my Jeep Info.
Thank you for your time,
Luckily there was a nice buggy there to winch me out real quick.
and obviously not good cast aluminum. There is no way you will ever get any kind of seal, it won't be flat and when you tighten the bolts you will put stress on it that will break it again. I don't think there are a shortage of
