extra wire under dash intermittent wipers maybe???
amc401
Maine
83 cj7 laredo amc401
I have never seen intermittent wipers on a CJ :confused:
i also thought that was odd kind of a new feture for cars BUT i got the picture from another cj website fourm and that was the answer that was given. realy not sure i check my manual online and cant seem to find answer. maybe sombody could check there cj. its right behind light dimmer switch
I went out and looked at mine and I have the same plug that is not hooked to anything. Think it might be for a tac because the orange wire is for a dash light and that is the only gauge you would have on that side.
well that was another thought. wow thanx so much for clearing that up i really appreciate it.
Intermittent wipers have a red connector that's the same design, and spliced directly through, the wiper switch connecter. FYI. If the module acts up, you just switch the plugs, and have standard wipers.
That plug is for optional fog lights, you will also find an single orange wire near the driverside headlight. It will be tucked up behind the headlight bezel, with a connector on the end of it.
How do you know that? I have never seen a switch on the dash for fog lights.
Im looking at a diagram and its showing the fog light switch with a red w/tr, gry w/tr and blue going into it... but it shows it as a different shape plug
Wind sheild wiper motor looks to be the same type of plug. holding it the way you are the wires go L-R red, wht, blk, Blu.
Diagram is from a 84 and up. The fog light was an option that never seemed to be used.
I have the same diagram, and yes just as you pointed out. The windshield wiper motor is.
pin. wire color
A---------BLUE
B---------BLACK
C---------WHITE
D---------RED
But the plug in the OP pic. does not match that.
ok well here is the thing the wire that comes down from wiper motor is the same exact style plug It fits right into this mystery female plug
Good im glad you got it working. :chug:
I stand corrected and I appoligize to everyone out there.
No reason to apologize. All input is appreciated.
Interior Dash Pad
