Build Thread Finishing Another Fella's CJ7 Build
I was wondering why the thread ended, I hadn't come across this before. Jeep looks good (love the EGA decal on the side). Now we need some pics with it's new shoes on.
Thanks, guys. I'll get some pics up as soon as I can to illustrate where I am with respect to the build.
As Sasquatch pointed out a while back, the exhaust on this vehicle didn't have enough clearance for the trussed AMC20 . I cut the exhaust off, including the tiny muffler, right at the back of the skidplate. I installed a Flowmaster 2 1/4" muffler, and it surely runs a bunch better. I think the muffler that was on it was partially obstructed or more sized for a lawnmower. Anyway, I need to think about how I want to run the new exhaust.
Next, I found a crack in the front passenger side of the frame while I was installing a front swaybar and disconnects. That's going to slow me down a bit, but I'll power through it.
Bee stings wouldnt be good for me , Im allergic. :eek: If you do find yourself in need of a driveshaft let me know via pm. I have a few laying around the garage.
I'm embarrassed to say, my CJ's been sitting so long waiting for me to get home and give it some love, that a nest of uppity wasps moved into the front passenger side of the frame rail. Negotiations were short lived, and war was declared soon after. Gaspipe eventually won the skirmish, but not after getting hit twice. Little bastage got me right on the back. I cut him down with a shot of PB Blaster.
I put in for a purple heart. :p
Anyway, I straightened a severely deformed rear leaf spring hanger, and re-bushed the leaf eye, and straightened and re-bushed the rear shackles.
While I was under there, I think my rear driveshaft is too long. Although the PO lifted the CJ, he also re-angled the rear axle. I need to look closer at it tomorrow. Additionally, I think my front driveshaft is too short.
Time for a few beers now. :chug:
Thanks Pete. I have to measure them up and see what I think I need.
Meanwhile, a question for the masses - would you do a rear disc swap, or a power brake upgrade?
Your rear driveshaft does look like it's inline with the rear axle yoke. This is how it would be if using a cv jointed shaft. Is yours? If not you'd want to go that direction rather than cut the perches off and relocate. I would think that'd be cheaper and def. less work.
I definately agree here. As far as the rear disc power brake question Id go with power brakes. Your AMC20 is built up pretty good with the one piece axles,trussed and welded tubes. Youve got time to take to slowly build up a Ford 8.8 if youd like to go disc and decide you need more beef.
Then power brakes it will be. Thanks again. Also am looking into a CV rear driveshaft. The PO worked hard to get the angle right on the axle, and the CV joint would be a nice thing.
I spent the evening getting rid of the accumulation of sand and muck in side the frame. First, I wanted to get that crud out of there to see what I still have, and secondly, the frame rails packed with :dung: makes it very hard to section and repair.
So out comes the garden hose. That crud got in there via water, now it's coming out via water. It takes time and some patience, but I washed a beach full of sand out of the frame rails today.
The good thing is the frame is in better shape than I thought it was, but needs a couple places repaired. I have some 3/16" plate on hand, so it shouldn't be a major item. The other thing I discovered tonight was the PO installed a new steel fuel tank. The bad thing was he didn't vent it. I remedied that tonight while the hose was washing the sand away.
Last thing was checking out the right rear drum. The adjuster felt funny, so I pulled the drum, and as I suspected, the internal brake cable on the adjuster had come off the guide, and the barrel adjuster was not doing it's thing. Stuff was all new inside the drum.
Sorry, I missed your question but yes, I'd probably go the power brake direction as well.
A suggestion on your tank. Give it a good coat of a quality paint before putting back in place. Dirt gets trapped between it's bottom and the plastic liner and acts as a sponge to hold moisture and it will rust the tank from the outside. I went thru 2 metal tanks before I switched to a poly one and haven't looked back since.
Did you see the rod end clutch linkage? If not I'll send you a link after work
Is that Chesty on the hood?
I got myself a dual 8" diaphragm GM style power booster, bracket and new master cylinder today via brown santa. I'll be installing that tomorrow. I'm not selling off the 35" MTR rubber just yet.....
Additionally, I ordered some 2.25" mandrel bends to finish the exhaust - two 45's and a 90. That should do the job of getting over the axle.
What I did get around to doing this evening was procuring an antique automobile registration for the CJ. It's a one time tag fee rather than renewing and paying more fees every year.
With luck, I'll be driving the CJ regularly rather soon.
I have to admit I love driving Vickis Laredo back and forth to work. Even in todays thunderstorms with just the bikini top. :cool:
I enjoy the simplicity of the Jeep. It's crude and somewhat archaic, but I enjoy that quality.
I still have my locomotive license, and really enjoy the old locomotives, too. It's not uncommon to be running a switcher that is sixty years old. I like the simplicity of the machine, the old style air brake, etc. - much more visceral.
