Build Thread Finishing Another Fella's CJ7 Build
Looks like you made it yours, nice job.
It's lookin' good. Did you have trouble getting that Flowmaster to fit? I had gotten one, the super44 delta I believe, and it had 2 1/2" at both ends but also an offset in and a centered out, which is opposite of what I needed. Did you have to angle your exhaust towards the frame and then tilt the muffler down on that side? Curious as to how you made it work.
Love the desert sand paint. I am just finishing up a ch7 and it is painted axles up, insideout desert sand. I was thinking of olive drab, but with the current military this works. I will put on the stars and my VN unit numbers on the bumpers with my serial numbers on the sides of the hood. The license reads VFW2455 as that is our local post. Has been a fun frame off build. Just fired it up yesterday, still have fenders and finish paint to do with a small amount of wiring. I slipped in a 350 chev with 350 turbo auto. It had an auto with the AMC 258 i6 / 4.2l six. Anyone out there needs either of these they are good to go. The six did smoke a bit after idling but ran well.
I live in Washington State, pm me if you are interested.
I've been traveling quite a good deal working this past year, and my progress on the CJ has been slow. The job trail has not been fun.
I've put a few miles on the CJ, and did some fun exploring with it, but realized I need to drag it forward a bit more. The 4.0 head conversion is working quite well, and the rebuilt suspension/brakes have been doing fine. Anyway, I've accumulated a pile of parts to fabricate/modify, and install as soon as I can. Tilt column, power steering and brake conversion are about to happen....:cool:
I'll add up some stuff here as soon as I get some pics together.
A big pile of parts arrived via FedEx & Brown Santa on Friday afternoon, but unfortunately I had to work today. Tomorrow, the install starts. I'll take some pics for y'all to see.
I started modifying the power steering brackets tonight. Looks like it's going to be relatively straight forward. The manifold/block bracket was already 'notched' somewhere along the line with the hot wrench, so I'm going to need to do some cleaning up the gnarly flame cuts, and reinforce some of that piece.
The steering box I got is an earlier flare type, as is the pump (double pulley for some reason...). I might just go with a HD mount for the box. I also ordered some new power steering hoses today, since the return line fitting was cracked, and the line I got at the junk yard with the box looked pretty dodgy. No sense working this hard to not put new lines in.
The brake booster install should be a PITA, they always are. Brake fluid makes everything crusty.
Lastly, I'm going to fabricate an improved throttle linkage setup for the MC2100. The one on there now won't allow for full throttle, and is basically made of worn out parts from the old linkage.
Fun, fun!
I'd considered making a bellcrank assembly, but decided simpler would be better.
As usual, I've procrastinated the hell out of this - because I hate doing things twice. I don't get to quote myself much, but what I've decided to do it make a throttle cable rig that pulls from the front. Simple is better for me, and I don't want to introduce any weird angles into the throttle shaft. I've got a 48" generic cable enroute, and will weld/machine a stay and linkage to make that work.
Looks like standard 51" pre-made 3/16" brake lines will work fine, but I'll need a 1/2" and 7/16" adapter at the prop valve. I always hated making double flares. And that length will give me loads of room to make some coils. The pre-made lines are under $4 each, too.
Moving ahead of myself, I got a dropped pitman arm for the PS box to correct the angle. My manual box had a dropped one, and it worked well enough - so I'm going to stick with that geometry for now.
Next, the PO said he had a 'locker' in the rear AMC20 . I suspect it's just welded spiders - I used to roadrace in the SCCA, and know darned well what a spool rear feels like. I bought a gasket today so I can pop off the cover and take a look in there, and make a plan. It's really not drive-able the way it is w/o tearing things up.
I ditched the OE fan (no fan clutch even...) and am planning to use a Ford Contour e-fan and a solid state controller.
Next update when I have some pics to share. And advice is always welcome.:chug:
