Build Thread First cj7 build 1985
You got alot done since I approved this thread yesterday. :D Nice work.
Well I'm a quick worker lol ;-)... That's why I was anxious, had a bunch of posts written up wanted to get them out.
One thing I did want to ask..... I have been pushing the car around alot mostly in and out of the garage and it feels incredibly heavy. I think something may be hung up. With everyone's experience here where is the first place I should look? I'm hoping that when I get her driving around a little more thing well start to loosen up a bit.
If its that hard to push Id be looking for a caliper or rear drum being hung up. Who knows what froze where with how long it sat.
Guess easiest thing would be jack up each side and see which tire doesn't like to spin... Why didn't I think of that sooner lol.
Looks great, you seem to be making progress which is always good. Keep the pictures coming. These folks here know jeeps inside and out.I will stay tuned!
Sent from my DROID RAZR HD using Tapatalk 2
My 83 should have the right set up. I'll look where the green wire goes and post back.
Thanks for the kind words guys... I appreciate the help with the wire I suspect it goes to the ignition control box... I'm not positive though
Lol thank you that gives me a great place to start I'm thinking of switching to a Msd 6200 ignition and bypass the entire module.. What's everyone's opinion on that?
I've seen different variations of this but this discusses the Msd unit more...
Ive used it without the MSD and liked it , but I switched carbs at the same time. Some people will say go with the H.E.I. and others lean this way. I tried both and prefer the Team Rush. It was two different 258s but both had the Mc2100. Im going to use the Team Rush with the MSD when I get that far on the Limited .
Alot of options... I have an Msd headed here tomorrow.. I'll probably pair it to the team rush mod ultimately
1980 CJ7 AMC 258 i6 / 4.2l : my green wire goes from the coil and disappears into the plastic sheathing. Only place a green wire comes out of the sheathing it ties into the back of the fuse box at D4. There is another green wire that comes out of the fuse box at the same terminal (they are tied together) and runs directly to the electronic control unit (C4). TSM wiring diagram seems to confirm. Good luck, you're making quick work of it. :chug: Guess my picture post worked after all.
That is some out standing work.. Now the electronic control unit is what? That is not the same as computer that controls emissions correct?
Just a few thoughts.... When I installtthe MSD unit will i be able to remove the old ignition box and all wires coming to bit and leaving from it, since I'll be eliminating the entire thing? Also I was thinking of installing it in the factory location is this a good idea?
