frame on a 1980 cj7
gitz676
- Millet Alberta Canada
- 1982 CJ5, 360 AMC, AMC 20 diff, 176 trans, dana 300 TC, dana 30 front diff.
Frames were not made to flex, suspensions were made to flex.
The older c-channel frames would sometimes crack because of stiff suspensions (9/13 spring packs).![]()
Do the Ouray/Silverton CO rocks count?Made to or not-They flex plenty off-road.![]()
Come on out and play in our rocks-You'll see first hand. :driving:
Frames in general were built to “resist” flexing, opposed to made to flex.![]()
The frame is made to flex.
frames are made to flex.
Tractors, pickup trucks, and Jeeps, all flex to a degree, but their frames were built to resist twisting.
I wasn't wrong, you somehow miss it.
One could ask the guys that build them. Throttle Down Kustoms builds some nice quality frames. If someone were to call their tech guys and ask them if their frames were made to flex their answer will be no.![]()
Call Kenworth or Freightliner and ask them-I already know the answer.
Posi-Do the tape trick I spoke of, on your Jeep. You'll see.......
, if you want to play you have to read all the posts. If you had, you would know using a tape on the frame wouldn't tell me anything I don't already know. Yes, frames are made to be as rigid as is possible.
