Suspension Front frame bracket shackle bushings are loose. new bracket, new shackles.
Trace63
Littlestown, PA
1983 jeep CJ7, w/1979 4.2
Yes. The bushings should be tight/snug fit and should not have the gap or play your pic shows. The stock outside diameter of the bushing should be 1" (the part that slides into the hanger eye, not the "flange part). Looks like your hanger eye inside diameter is larger than that. I've heard of people getting replacement hangers that were 1 1/8" inside. Don't know why/how, but a problem for sure.
Aren't YJ hangers larger diameter than CJ ones? Of course they are also wider as well (2.5" vs 2"). Any chance those new hangers are the wrong ones? I'd contact where you got those hangers to see if they can answer or send replacements. Or perhaps get a set of YJ bushings.
Thanks for helping out.
The new ones I got were from Omix, are definitely the right ones and cost around $15 each and are made in India. All dimensions other than the bushing hole diameter are perfect, I just think it's a case of the manufacturer not keeping close tolerances at that step in the manufacture.
I talked to a guy at Bonefish, where I got my shackles and he confirmed what you said, that the inner diameter should be 1"on the brackets. He didn't even try and sell me the ones they make, which cost $75 each. I'm sure they work better but I'll try and make the ones I have work and if they cause bushing failure down the road, I'll consider the expensive ones or do better research in hopes of finding a better bracket for less than 75 each.
I have a torch and a couple of big hammers and that and a few hours seemed to work on the fronts. The backs are welded into a loop(the fronts were not) so I'll have to cut that first but I should be able to at least make it slightly snug for the bushings.
