Front Hubs & Towing
Front Hubs & Towing
BusaDave9
Always Off-Roading Jeeper
Featured
Durango, Crawlarado
I have always thought the front hubs should be unlocked when getting towed. This keeps the front axle and diff from rotating.
Then I got TeraLow gears for my Transfer Case and the instructions say when towing to put the transfer case in neutral and lock the front hubs. They underlined it for emphasis.
Of course the gear ratio in the T Case shouldn't make the difference. Does anyone know why it would be better to have the front hubs locked while towing?
I'm just guessing since I have no experience with the TerraLow gears, But I'd imagine the design requires the front and rear driveshafts to rotate at the same time for some reason. Don't forget the rear driveshaft (unless you disconnect or remove it completely) will still be rotating the gears in the TC. So my guess is there is an oiling requirement for the front gears, nessitating the front hubs be locked.
Whatever the reason, If they say it (and underline it even) then I'd just do it. Your drivetrain has changed from stock, so the normal requirements/instructions have changed and are void.
I do full float conversions on the rear axle and disco both sets of hubs.
That's a good idea. I think those full floating conversions were more common in the '80s. They also help when you have problems with your rear end when you are away from home. You can lock your front hubs and drive home in front wheel drive. Twin shift levers for the Transfer Case also helps avoid rotating a broken diff.
thanks Busa, the pic you show is full floating but still uses a drive flange so it does not disco, I put a set of warn hubs such as are the front axle also, this way I can disconnect the axle same as the front. With both axles discoed I can flat tow without worrying about the tcase or tranny.
I actually started this on a jepp I had because I had busted an axle and had to get towed out. I run a lot of trails by myself so I decided I needed a way to get home with a broken axle with no one around. The benefit of flat towing was secondary. I figured that out one time I was about to go tow my Jeep to a show. (use to have a Tuxedo Park Park that I would show) It never got any prizes but a lot of guys would ohh and ahh over it.
As CJ owners we usually have full floating axles in the front come with our Jeeps when we buy them. guys with TJs and JKs are not so fortunate and have to convert. I know that warn has even stopped making kits for this conversion as it is not as popular as it used to be.
Sounds like more work and $ even if parts were still available. I guess I'm just gona pull it around the way they tell you too, do kinda worry about having the thing go into gear on a pothole or something but it would have engage the the Transmission . and the T case to grenade the motor. Not very likely but have heard of at least one guy who got to his destination to find a rod through the block :(.
More in line with the thread-I have a CJ3b that has been towed all over the place and the hubs were allways left free because we did'nt know any better.
Yes, a full floating kit and hubs for the rear can get expensive. CJ owners think it's worth while because we have to get rid of the factory 2 piece axles if we want to do any hard off roading.
You could also remove the rear drive shaft when getting towed. Then the only thing rotating would be the rear end. Removing the drive shaft can be a pain for a short trip but if you will be towing long distance it's worth it for the peace of mind.
This is a good discussion for me right now!
I got the '81 Laredo to tow behind our Motorhome. There has been numerous discussions about this on numerous sites and usually disagree .I understand that the Transfer Case may not get proper Lubrication when the Output Shaft is Turned rather than from the Input Shaft.
I then bought an Owner's Manual for my 1981 CJ7 . It states to; shift the Transmission into Gear and the Transfer Case into Neutral, stop every 200 miles and run the Engine for about a minute with the Transmission still in Gear and the Transfer Case in Neutral. It doe state that Cherokee, Truck and Wagoneer should have the Hubs Locked.
I talked to Larie at Jeeps R Us about this and he says to put the Transmission in Gear, Transfer Case in Neutral and Un-Lock the Hubs, he then said to just stop every 300 miles and run the Engine with the Trans in Gear and the Transfer Case Un-Locked to Lubricate the Transfer Case.
I am still confused about this but I would rather not have both Drivelines Turning when I am Towing the CJ7. I then went looking for a Full Floating Axle Conversion; Warn sold this to Randy's Ring and Pinion. I talked to Randy's Ring and Pinion and they will not be building this kit.
I would like to do a Full Floating Axle Conversion and have some older Warn Kits at some time soon. It does sound like I need to talk to BajaEdition about a Full Floating Conversion.
That's what I was thinking, might be worth the 10 min. to drop/install the driveshaft. Our main destination from home is 300 mi. +- or about 6hrs. Be nice not to have everything whirling away at 65 mph.
When I said to lock your hubs when getting towed I was talking about the Dana 20 Transfer Case but it also applies to many other gear driven transfer cases such as the Dana 300 and Dana 18. I don't think it applies to some chain driven transfer cases such as the QuadraTrac that came in some jeeps in the '80s. I wonder if the manual you have is referring to the Quadratrac.
most of the chain driven transfer cases came with semi floating axles (TJ) or vacuum disconnect (YJ) so the front was spinning anyway.
I have to agree with the cost of a full floating kit, around 800 clams with hubs, and then labor, but the benefits are huge. Besides towing, and getting the weight off the shaft, you can also disconnect a shaft if you break it and drive home (If you have a locker). I really do not suggest this to everyone, but If you want the benefits it is there. Just getting the weight off the axle is like upgrading to bigger shafts.
You all can do it how you like, but I towed my '74 (T-150 3 speed and Dana 20 TC) 2100 miles 1 way at Hiway speeds (+) over 3 days when I moved across country. This was after extensive research and reading a few factory manuals.
I unlocked the front hubs, put the Transmission in HI gear and left the Transfer Case in neutral. The driveshafts both stayed in place.
The only problem I have to report to this day is the Speedo failed somewhere along the way (I guess it didn't like the 70 MPH speeds!).
So for me (and my setup) I will continue to do this when I flat tow.
ok interesting thread....i have an AMC20 with full floating axles. is this truly a stronger setup? also, does this require 1 piece axles? i bought the jeep with this setup and have been considering inspecting the insides soon to find out if its one piece axles or the POS 2.... want to make the jump from 33s to 35s so wanna upgrade the 20, if i cant pick up a 44 for cheap!!
$20.00
  10.0%
