Electrical Fuel gauge reads full. 85 CJ7
Molotov
San Antonio Tx
85 CJ7, 4cyl, lots of rust
fuel gauge reads full all the time. Is it a short to ground? Any way to check without dropping fuel tank?
Either a short or the sending unit is stuck
U can easily check the ground issue by running a jumper wire to the gauge and see if it works correctly. If it does then ur issue is in the wiring
Sent from my E6810 using Tapatalk
BTW, if you don't mind making a hole over the tank, you can pull the sender without dropping the tank.
