Fuel Line, Pump to Carb
al2ride
OH
76 CJ7, Fiberglass Tub, 78 4.2L, 78 Turbo 400, 82 Dana 300, 77 CJ7 Dana 30 Front Axle, 79 Bronco 9 inch Rear Axle, Weber 38 DGEV, HEI Distributor
Anybody know where I can get the pipe that goes from the mechanical fuel pump to the carb. I found some at the local store but they are either too big in size or do not have the correct flare to fit the fuel pump.
You may need to make your own. Get a tubing bender there only about $10. And a flaring tool. I don't know how much they are new I was lucky enough to get one at an estate aution for $7. But the tubing bender is well worth the $10 for brake lines and fuel lines. Even if you buy the prebent lines I found that you still need to bend the lines in a few places to make them fit properly. Try looking at morris4x4jeep.com they have alot of parts hard to find. Or www.4wd.com
I have the bender but not sure if the pipe is flared or the type with an oring. Ill have to take what i have appart to see what the short pipe thats there right now looks like. Thanks for the response.
I just bought a line from orielly and bent it myself. Take your old line in to match it up
Heading out there. I pulled mine off and it is flared.
The fuel pump fitting on my 77 is the same as a 5/16 brake line. this was available at the O'Reilly auto parts in 2,3 and 4 foot lengths, it bends easily also. I think you will find that is a double flair, but I am not positive.:D
