Fuel line
Fuel line
davey25
Ontario, Canada
78 CJ5..258 T150 Dana 20..wide track axles..ps no pb..all stock suspension..31x10.5...previous 76 cj5, 80 cj7,03 TJ ..
Ok I'm doing a build but seems impossible to get a build thread on here..anyways quick question...I'm leaving the body on so while replacing my fuel line it's nearly impossible to bend the line over the shock mount..so I chose to use rubber from this point to the tank.also cleans up a bit better so I took it through the frame..going to put some protection at entry and exit point though..I've heard of vapour lock issues but Im still running the majority of the line as steel..anyone have any insight to what I've just done..thanks guys
That looks good to me. Have you submitted a build thread for approval?
Tried no response
To get a build thread, you enter the forum and submit a new post just like you would any other forum, the thread wont immediately show up because it has to be approved by an admin.
Vapour lock, as I understand it, is caused by the lines getting hot enough to vaporize the fuel in the line. It is unlikely that a vapor lock problem would occur in the fuel line that far away from the engine.
