Fuel Not Making It To The Carb!
Vvajk
HELP!
Here's the situation. I have the stock I6 AMC 258 i6 / 4.2l engine but with a Motorcraft 2100 carb, with manual choke. Right now, the only way to get the Jeep started is to actually pour gas from a can into the carb. After I do that, it fires right up and runs great, but it will not start by just turning the ignition. So I'm thinking, obviously fuel is not reaching the carb.
I pulled the fuel line off the carb, and turned the ignition, and fuel DID start to flow from out of the end! What the heck, right? Well, I'm sitting here at work, and it just occurred to me that I also have an inline electric fuel pump that is manually activated with a switch from inside the Jeep. When I flip the switch, the pump definitely kicks on (makes noise) but Maybe it's not pumping? What do you guys think, could this be my problem even though cranking the engine over still seems to be pushing fuel through the line? Maybe the inline pump isn't working, and without its help, there isn't enough pressure to deliver fuel to the carb?
I'm pretty amateurish about this stuff, I would love to hear from some of you guys what you think?
