Fuel Tank/Frame corrosion prevention
65reissue
Alpena, AR
77 Jeep CJ5 - Renegade - 304 w/3 spd - pretty stock at the moment.
Hey guys...I'm about to drop my fuel tank to replace the sending unit. I'm on the front end of my build...so while I have the tank out, I want to coat it/paint it to prevent rust...and make it pretty. What do you guys suggest as far as prep and coating? I have considered POR-15 ...and Chassis Black. Is that the route to go? I will be eventually taking the body off and doing the entire frame so would like the info for that as well...I assume the same products would work? Any help (or advice) would be appreciated...thanks.
$75.00
  37.5%
