Gas pedal/pad install - can't believe I have to ask
CJ7inNH
Southern NH
1983 CJ7
6 cyl, 4 speed
Dana 44
4 inch skyjacker lift
weber carb
Seems like it should be so simple, so of course it's a pain in the...
Bought a replacement gas pedal (just the plastic pad), since the old one was pretty much just a smooth piece of plastic.
How do you get the little pin out that goes through the back of the pad to hold it onto the metal arm?
Looks like it is flared out at the end so you can push it in, then it will not back out.
Thanks.
