Gauge Questions
Gauge Questions
phinleft
Baton Rouge, LA
78 CJ7, Amc 304 V8 - AMC 20, DANA 30, Quadratra Trac TH400, 35" Mickey Thompsons MTZPainted LSU Yellow/Gold. Modified with 4bl Edelbrock Carb.
My gas gauge is an aftermarket stand alon installed by the previous owner. WHen I start the cj, the needle goes from E and drops down below E. When I stop cranking it goes back to E. I am thinking it is an electrical but everything seems to grounded correctly.
What is the correct lenght for a speedo cable on a 76 CJ5 ?
different gas gauges work on different resistances in the sending unit, they have to match. If a PO changes on and not the other it could be a difference in tolerances
Just a thought
Just a thought
Good thought, I was affraid to touch this but You got good smarts.:notworthy:
No mix and match on sending units and guages.
