Got A 4.0 Head Today
ThisGuyUKnow
Full Time Jeeper
Featured
Harleysville, PA
1986 CJ7 Laredo 4.0,Nv3550,D300 Twin Stick,AMC20 3.31, 31 BFG
Honda vtx1800c
Thought I would add that I plan on running the stock AMC 258 i6 / 4.2l intake and carb once I get the head and exhaust header on. I will eventually go 4.0 injection as well but my pocket book is getting mad at me.
I offer one bit of advice. When you re assemble put the head and manifolds together before you put the head on the engine, go ahead and do the first torque on everything, It is a whole lot easier than putting the manifold on with the head bolted down. You will need help or a hoist to set the head . :cool:
So you are saying while i have the head off I should torque the exhaust and intake onto it? Won't that make it a PITA trying to drop it onto the block? I am curious if i will have anyissues getting the old intake and the new exhaust to play nice?
not nearly as big a PITA as getting the manifolds lined up and reaching the bolts to get proper torque on all the bolts. And you will get the chance to put the wrench on after 500 miles to re torque the bolts.
Is the 3 angle valve job worth the extra $$$$? I see u did it on your head. I was just goig to have it refit to stock to save money but if it is worth it.....
Are u running the carbed intake? What exhaust did u use? Which head gasket did you use? Also which intake gasket did u use? The ones for a AMC 258 i6 / 4.2l ? Or for the 4.0? Do you have to grind away any metal to get the intake and exhaust to fit.
I don't think the 3 angle will cost much more than a stock grind but check with your machine shop It has been SOP for me for quite a few years.
I use a carter 2 bbl carb. the head is 4.0 the intake is AMC 258 i6 / 4.2l the exhaust is a cheap stainless steel header that fits the 4.0 that I found on E-Bay. I preferred the header to the stock 4.0 exhaust as I hope it will not be as inclined to crack. SS has a very high rate of expansion and even with the expansion joints the stock don't have enough flex.
use the 4.2 manifold gasket and the 4.0 head gasket.
There is a small bit of grinding that is needed on the intake manifold to mate with the exhaust, another good reason to assemble this before you set the head.
I think you have 1/2 inch head bolts but if you have 7/16 head bolts you will need some shims from Clifford to keep the head centered. :cool:
The machinist said I was looking at 210 worst case scenario to magnaflux the head remove the broken stud and cut the valves at three angles. I guess hats not bad but he saidthere was about a 50/50 chance a junkyard head will be any good. Seems pessimistic to me but I hope it will work out.
He is telling you true, they like to crack between the valves. AMC 258 i6 / 4.2l 's are worse.
Gibson Stainless Headers 1995/1996 Jeep Grand/Cherokee : eBay Motors (item 400103912180 end time May-17-10 12:55:36 PDT)
these are pretty close to what I used on my truck but I don't see any reason not to use the stock header. I would find a welding shop to do the crack rather than a muffler shop. some one who can run a stainless steel rod should not be too big a problem.
He is telling you true, they like to crack between the valves. 258's are worse.
ok IO not to be rude but if those are the headers you used then you and I have a different definition of cheap.:eek: 400 bucks? What abot he ones I linked for 85? Maybe I should just weld it and if it cracks again just reweld It over and over? Will the cheap ones I found not perform well?
:laugh:
We pretty well agree on what cheap is, and these are not They are a lot less than a good header . If I were in your shoes I would weld the ones you have. Before you send the head to the machine shop I suggest you bolt the manifolds to the head, pre heat a bit with a torch and weld the crack. If it is going to crack it may do it right after it is welded. I would have a talk with someone at your local welding supply for rod recommendation. the ones I have seen in the junk yards that were re welded were welded in place while still on the car. They were pretty sloppy and it is no wonder they cracked again.:cool:
:laugh:
what about that ss headers I linked In an earlier post? They are only 85 bucks and may be less hassle than me trying to learn to weld
Machinist called today, the head is magnufluxed and is free of cracks. Now he is just going to cut the valves at three angles and put it back together.
$35.00
  17.5%
