Grinding into reverse
- Springfield, Missouri-U.S.A. Earth
- '85 CJ-7, 258/4.2L 6cyl. Bought new in 1985. Full cage, Warn 8274 winch, Ford 9" rear, front/rear Detroit Lockers w/4:88 R&P. T-5 tranny and 4:1 t'case. 33X12.50-15 BFG/AT, MSD ign, on board air---
I live in the Mojave Desert. Pen S'mesh oil has work well for me for many, many years. That's not the issue.
Pilot bearing, don't think that it either.
You have a diaphragm type pressure plate. My bet, is when you remove the bell housing. You'll most likely see one or two of the diaphragm's 'fingers' are just a bit lower than the rest. That means a broken p'plate spring. The clutch disc is not fully releasing(dragging)contact from the flywheel.
Please let us know(pictures maybe)of what you find.
