Harmonic balancer/water pump
Geep
Long story : Recently had the front and rear main seals replaced on my 304V8. They also replaced the water pump and timing chain while they had it apart. Problem is (?) they replaced the water pump with an after market pump that wasn't molded just right. After all was put back together, they fired it up and claim the harmonic balancer hit a burr on the water pump case with such force it cracked the harmonic balancer. They fixed the burr problem and replaced the harmonic balancer, at no cost to me. Now after about 250 miles the front main is leaking again. I called the shop and told them of the situation and they said bring it back and they will take a look. I don't want them to get any deeper into my pocket and I told them that ! Question is, Would the harmonic balance hitting the water pump hard enough to crack it, cause damage to the new seal ?
