HD steering box mounts/brace
was gonna do the brace and just keep the factory box mount? didnt know if the mount was overkill if you did the brace...and the pdf for the brace says to remove the rear bolt for the hanger, mines snapped oof in the frame?
sorry i meant the hanger on the frame![]()
Vickis Laredo has 35s. Let me tell you Ive been going through the whole steering system. I started by getting the beefier rugged ridge tie rod and drag link cause my ends where worn out and it came as a kit. I definately recommend that. When I went to get an alignment they told me the stock 2 piece bracket was loose but the alignment came in.
It turns out that the bolt that was loose was a very difficult to get at reverse Torx bolt. I already had a used Big Daddy bracket so I decided to swap it in. When I took off the old stocker it was rusted and cracked along with that bolt being loose and stripped. I put the new bracket in and used lock tite on the bolts. I then needed another alignment.
The steering was always a little loose and it finally came time now for me to swap the gearbox out. When turned lock to lock Id get a banging sound. I went with an '83 set up so I got a new pump and lines as well. While putting in the new gearbox I notice some stripped threads on the rag joint.
So whats my point for this long winded post? Your Cj came designed for 28 in tires. IMHO you need to upgrade everything. People will chime in and say their 2 piece bracket served them well for years. Thats fine but when it starts to fail its a white knuckle ride for sure at the least. People will say they run without a brace without a problem. I think if your gonna wheel it the added support is easily worth it. From where my used one was broke at I can see the added value in the one JR74CJ5 posted. Once I get the one he posted for my year Cj then Im upgrading the steering shaft itself and the list goes on ...
