Head light wiring up grade
Jimbos76cj
Full Time Jeeper
Featured
St.Cloud FL
83 CJ-7.. 4" YJ springs front rear, J-10 44 front/AMC 20 rear,6 cy auto dana 300 35' bfg Done and gone!!
Ask me about my head light upgrade harness!!!
I think 20 amps is a bit much for the breaker. I thought the lights were on a 10 amp fuse.
Thanks.. Ill look into the stock fuse size.. I was staring at them in the isle and couldn't remember if it was 10 or 20..
Ooh I did some quick high school math that was lingering in the back of my head and came up with this
2 bulbs x 55 watts = 110/12 volts x 10%= 10.1.. So I'd be over my amperage (barely) with the 10 amp breaker there is no 15 amp breakers that Ive seen locally.
High beams 2x65= 130/12 = 10.8 x 1.1 = 11.9.. Ill keep my eye open for a 15 breaker but for now will run the 20's
I put in 100/80 halogen bulbs and ran high and low on at the same time. Worked great for a short time, then melted. That was 30 amps. (Watts/volts=amps)
Did a similar relay for each beam. 12 gage to each bulb from each relay. I put the relays inside by the OEM fuse panel (75 transplant fuse panel and harness). Nice and dry. I like mud and water. . .:D
Nice write-up!
Nice write-up!
Wow.. I'm surprised it help up to that load at all..
Many years ago with a bigger fuse . ..
I fully understand wire gauge and fuse size now. :D
Wait a minute. You got to learn math in highschool?? :confused::wtf:
:D Nice job on the write up. But shouldn't the breakers go before the relays, right after the solenoid? And are they the "resetting" type breakers since they're headlights, so if they do trip it won't stay dark for long.
Jimbo,
I really like the relays you made for me !!! They rock!!
I'm adding fog lights, could you make me up a harness for them?? 2 on the end of the front bumper! I'd like to switch them with a switch mounted to bottom of dash to the left of steering wheel. I'd like for the relays, wiring, etc to match!!!
Thx
Todd
I think you will be fine with the 20A protection. It will still protect the wire if you happen to have a short circuit.
