Headlight woes, trying to fix
Sieldan
Alabama
1981 CJ-5 AMC V8
The white thing is a ballast resistor used for a points distributor. Why is it on your 1981 Jeep? Where do the wires on the BR come from and go to?
Well, there is a AMC 304 in there. I'm not sure what kind of dizzy it has. I'll take more pics tomorrow. But thanks for the ID.
But to the headlight issue, I was able to figure out what was what. And I now have a nice toggle switch next to the headlight switch for Hi/Lo beams. Relays for the actual circuits. Just need parts. Lol.
Sent from my SM-G930V using Tapatalk
Well, there is a 304 in there. I'm not sure what kind of dizzy it has. I'll take more pics tomorrow. But thanks for the ID.
That is awesome. When the wiring for my foot switch came undone it really messed with all of the lights until I got the wiring figured out. Having the dash mounted switch would be nice.
Remove the distributor cap good chance you'll find a set of points. If so the engine build date would be through 1970-74.
Yup! I would think you would want to do some more research by checking the serial #s on that engine.
No build date on the engine, the only build date is on a tag attached to the right side valve cover and I'm sure that's long gone. Really doesn't matter it's a 70-74 engine.
