Heater and vent controls
bones
Eureka Ca
!983 cj5. 258 engine 4sp stock, 2009 h3 hummer.
I am working my way up from the bottom and now I am at the heater. I finally got all the heater and vent controls to slide . Only broke one of the retainers that hold the slider in the dash. Are they replaceable? And how do you get it out?
Also is the vent outside over the dash supposed to be open when using the heater. Half a pull opens the passenger side ,full pull opens the drivers side. It seems like water would come in in the heat position. Any way thats how mine is working. Forgot to say mine is a 1983 CJ5 .
I also wanted to say how glad I am that I found this sight. The answered Questions are a great help to me and everyone else. And thanks again to my posts. Bones
I think you will need to replace the whole cable but it won't be too much cash. check our morris 4x4 for the heater brake down and parts.
actually the vent leaks all the time when it is raining. I think you will find a drain on the duct someplace.:cool:
Also is the vent outside over the dash supposed to be open when using the heater. Half a pull opens the passenger side ,full pull opens the drivers side. It seems like water would come in in the heat position. Any way thats how mine is working. Forgot to say mine is a 1983 cj5.
Here's a pic courtesy of Elwood in case you lose your way.There should be a rubber hose by the battery that drains the vent.Its about 1 1/4" in diameter
